mariosomma
Apr 09, 2021Aspirant
Orbi WiFi 6 Dual-band Router(RBR350) : Satellite does reconnect after a power outage of 6 hours
Hi There, I just purchased a RBR350 with a single satellite (I'll call this Sat 1). All 2 devices are on the same firmware (V4.3.4.7_1.9.53). My network home (Router + Sat1) was working fine and ...
- Apr 16, 2021
FURRYe38 wrote:
mariosomma wrote:Hi There,
Thx a lot for the reply..
The mean distance between the router and satellite is closed to 16 feet. 16 feet is too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.16 is NOT too close
MORE than 30 feet is too far
please check this with Netgear support
Apr 09, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
The RBS should auto re-sync if there was a power cycle.
- mariosommaApr 13, 2021Aspirant
Hi There,
But in order to have the to have the RBS discovered from the RBR I had to put the RBS very close to the RBR (2 feet) and after a such a successfully discovery it seems the RBS is auto re-syncing in case of a power cycle.
Unfortunately from the orbilogin.com portal I can see the RBS has a Backhaul status set to "Poor". Please refer to the attached for details.
Indeed the devices attached to the RBS are experiencing a not good Wi-Fi covering signal (i.e, during a video conf call .. both the voice and the video are getting a lot of breaks.
Any suggestion , experience to share please...?
Thx a lot again..
Ciao.,,Mario.- FURRYe38Apr 13, 2021Guru - Experienced User
So the RBS will not re-sync unless it's 2 feet away from the RBR?
If so, then the RBK system needs to be checked either by NG or returned and get another set. The RBS should re-sync automatically at greater distanced beyond 2 feet. 30 feet should work as well.
- vajimApr 13, 2021Master
- FURRYe38Apr 16, 2021Guru - Experienced User
The mean distance between the router and satellite is closed to 16 feet. 16 feet is too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.- vajimApr 16, 2021Master
