plainblackguy
Mar 02, 2020Tutor
Orbi Wifi 6 missing config command
I just bought an AX6000/RBK852. When I go to debug mode and enable telnet, I can log in fine. But the "config" command that was there on my old Orbi is missing. I need to be able to split my wifi int...
plainblackguy
Mar 02, 2020Tutor
For the record I've tried setting it with the "uci" command, but it doesn't survive a reboot. I type:
uci set wireless.FhAp2.ssid="networknamegoeshere"
uci commmit
reboot
And before the reboot if I type "uci get wireless.FhAp2.ssid" it does return the network name that I set.
