plainblackguy
Mar 02, 2020Tutor
Orbi Wifi 6 missing config command
I just bought an AX6000/RBK852. When I go to debug mode and enable telnet, I can log in fine. But the "config" command that was there on my old Orbi is missing. I need to be able to split my wifi int...
ZOOShen
Mar 14, 2020Star
plainblackguy wrote:I just bought an AX6000/RBK852. When I go to debug mode and enable telnet, I can log in fine. But the "config" command that was there on my old Orbi is missing. I need to be able to split my wifi into 2.4 and 5ghz ssid's or a lot of my home automation devices refuse to connect. What am I missing?
Anyone here want to do some experiment?
go to http : // router IP/debug.htm
enable telnet
and then
telnet to your router IP,
cd /etc/config
and then edit the "wireless" file for the 2.4ghz SSID (may be using vi). Reboot. to see if that will work...
I can't play with that, because many ppl in my house is using the router..
gb777
Jun 20, 2020Apprentice
How do you enable telnet on the debug page?
Mine shows:
Basic Information
Firmware Version: V3.2.15.25_1.3.15
CPU Load: 13.79%
Memory Usage(Used/Total): 438 MB/866 MB
System Uptime: 0 days 01:35:13
Debug Log Capture
Start Debug Log Capture when boot up
Enable LAN/WAN Packet Capture
- ekhalilJun 21, 2020Master
In the latest firmware, telnet is always enabled, so there is no checkbox for that any longer.
- gb777Jun 21, 2020Apprentice
I have been trying to reply to your post with a statement that the telnet interface is not automatically enabled after a reboot and with instructions on how to enable it.
Because otherwise, wow.
- FURRYe38Jun 21, 2020Guru - Experienced User
Possible that did you have telnet enabled already and upgraded FW since prior version that had telnet as a debug web page available in the UI and have not done a factory reset? I've done a reset and telnet is not enabled for me. I would presume that by default telnet is not enabled if a FW update and factory reset is performed.
ekhalil wrote:In the latest firmware, telnet is always enabled, so there is no checkbox for that any longer.
- AceHackAug 21, 2020Aspirant
I'm on an AX6000 and I can't get 2nd wifi split out to survive a reboot.
If I run
uci set wireless.FhAp2.ssid="WiFi2GName"
uci commit
/etc/init.d/wireless restartThis will make a 2nd wifi show up for a period of time until a reboot.
Also "config" is not on the system.
And with nvram, wl_ssid is always set to NETGEAR no matter what I do, and setting wla_ssid only changed the wifi name in the netgear UI nowhere else. setting wlh_ssid will change both the 2G and 5G ssid.
Any suggestions?
