plainblackguy
Mar 03, 2020Tutor
Orbi Wifi 6 missing config command
I just bought an AX6000/RBK852. When I go to debug mode and enable telnet, I can log in fine. But the "config" command that was there on my old Orbi is missing. I need to be able to split my wifi int...
ekhalil
Jun 21, 2020Master
In the latest firmware, telnet is always enabled, so there is no checkbox for that any longer.
gb777
Jun 21, 2020Apprentice
I have been trying to reply to your post with a statement that the telnet interface is not automatically enabled after a reboot and with instructions on how to enable it.
Because otherwise, wow.
