Cerbeus's avatar
Cerbeus
Initiate
Apr 21, 2020
Orbi WiFi 6 Passwords
I'm trying to change my Orbi password but I'm having a devil of a time doing it.  It would help of course to know Netgears policy regarding router passwords which I know nothing about.  Is there a maximum length  they can be?  6? 10? 15?  20?  25? 30? Well I know the minimum length but again I'm not sure if there is a maximum one.
I'm using the "acceptable" symbols I think but yet nothing seems to be happening when I click on "change password". Any advice?
  • Are you chaning the admin log in paswword?
    if so, then NG likes 1 capital and a number in the mix and a minimum of 8 characters. NGorbi850 for an example.
  • FURRYe38's avatar
    • Cerbeus's avatar
      Cerbeus
      Initiate
      Thank you,.  Found a easy solution, it was right in front of me the whole time but thanks for trying to help.
