Partha21g
Jan 27, 2021Aspirant
Orbi Wifi 6 PRO SXR80 Printing across SSID
Dear Netgear community, i need some help with my latest set up where i am trying to print across two SSID.
Router and Satellite: Orbi Wifi 6 PRO (SR80) with two satellites running latest firmware 3.2.0.108. Its a home mesh
SSID Details:
SSID1: Using WPA3 authentication with default vlan profile with network and client isolation both off. This has my mobile devices and desktop
SSID2: Using WPA-PSK/WPA2-PSK authetication with iot vlan profile with entwork and client isolation both ON. This has my printer HP 8610 deskjet.
Post the latest firmwate upgrade, If all devices are only in the same SSID2 can I use the printer. If my printer is in SSID2 and my devices like laptop are on SSID1, i am unable to find the printer / print.
I have tried removing the vlans, changing the network and client isolation but nothing works. This used to work before the latest firmware upgrade. Unfortunately my printer does not support WPA3 authentication and cant move it to SSID1.
Is there any suggestions / workaround / fix to seemlessly stay connected and work?
Thanks in advance.
Partha
Please vist and post about this over in the Orbi Pro forum:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
Thank you,
- Partha21gAspirant
thank you have posted in the correct community. Thaks for your assistance.
- RaghuHRNETGEAR Expert
Hi Partha21g
Please send the debug files. You can log in to SXR80 by accessing https://<ip address of Orbi 6>/debug.htm
Click on start capture and wait for few mins before you save the debug logs. Upload into google drive and send me link via PM.
Hope printer is pingable.
Thanks,
Raghu
- Partha21gAspirant
thanks for your assistance. Printer is not pingable. attaching debug log
https://drive.google.com/file/d/1P7eF584DsCfPaygkfErgs6dIFe7L2-aQ/view?usp=sharing
