denizevren's avatar
denizevren
Follower
Jun 26, 2020
Orbi Wifi 6 Proper Initial Setup Method for guaranteed Ethernet Backhaul?
Apologies for the noob question however given the amount of negative reviews and issues I have read about trying to implement an ethernet backhaul connection between router and sattelite, I feel like I have to get down to OCD level details for a flawless initial setup.
I have just purchased the Netgear Orbi Wifi 6 Mesh System and I'd like to know which out of the box setup method is best for a guaranteed ethernet backhaul connection:
1) - Start with the router pre-connected to the sattelite
- Turn on router first but leave sattelite turned off
- begin setup on router, THEN turn on sattelite and have it connect to router on the already pre-connected cable
2) - Start with the router pre-connected to the sattelite
- Turn on BOTH router and sattelite THEN begin setup procedures
3) - Start with the router NOT pre-connected to the sattelite
- Begin setup procedures on router, THEN turn on sattelite and have it connect to router wirelessly first
- Finally, plug in an ethernet cable between router and sattelite
4) - Start with the router NOT pre-connected to the sattelite
- Connect sattelite to router wirelessly first
