JasonPaf's avatar
JasonPaf
Orbi Wifi 6 RBK 854
Hi,
    I have an Orbi Wifi 6 system with 3 satellites. Works great.
    In fortunateny remote access from internet (outside my home) to Orbi routeur webpage via DynDns address doesn't work.
    -> A DMZ zone is defined from my fiber box on Orbi routeur.
    -> DynDns also work on the Orbi settings.
    -> I can remotely access to my domoticz web page from internet with an open port on it.
     -> I can remotely access to my IP cemera also with open ports.
     -> I can remotely access to Orbi routeir with my android app from anywhere.
     -> OpenVPN also work from internet.
    BUT I can't access to orbi web page from outside, even if remote access seem to be properly activated in the advanced settings.
    Any idear ?
Thanks a lot !!!!
  • Same thing here.   Cannot get to the login page from outside my network even though I have it enabled.  App works from outside network. Orbi 850
    • FURRYe38's avatar
      Im thinking that NG has removed web page remote access from Orbi AX systems. I have both 7 and 8 series and notice that Remote Management on the RBRs web pages are not gone from v4 FW. I see that the blue popup at the top of the RBRs web page mentions using Orbi app to access the RBR using the app remotely. I presume that NG maybe moving away from web page remote management support and going with just Orbi app. Maybe a security reason. Something to ask NG support about and see.
      • JasonPaf's avatar
        JasonPaf
        Thanks all for reply !!
        Good to know that I'm not the only one !!!
