Windy752
Feb 20, 2021Tutor
Orbi WiFi 6 RBK352 AX1800 and Lenovo Z51
I have just installed an Orbi WiFi 6 RBR350 and satellite to replace a Virgin Hub 3. Set the Orbi up with the same SSID and password as the Hub 3 and all my devices (Asus laptop, iPhone,iPad, Raspber...
- Feb 20, 2021
What wireless card is in the lenovo?
What driver version is it using?
many people update the driver through windows or lenovo. They rarely have the latest driver. And if its an intel card, get the driver from intel as the versions that windows/lenovo have didn't recognize AX
Feb 20, 2021Guru - Experienced User
- Windy752Feb 21, 2021Tutor
Thanks, I downloaded the driver from the Intel website and it worked. Had to install the driver manually as the Intel driver check as well as the Lenovo one and Windows all said the driver was up to date. I suppose it makes sense as the Z51 is now obsolete and Lenovo will not have udated the driver compatibility. Anyway I have WiFi connection now which is the main point.
