beansontoast
Jun 06, 2022Aspirant
Orbi Wifi 6 RBK353 - port forwarding turns off after a few days
Hello! I'm on firmware V4.4.0.10_2.10.63. I've set up fairly standard port forwarding. It works when I first set it up, but then after a few days - it stops working. I can go in to the setting...
Jun 06, 2022Guru - Experienced User
Have you set up IP address reservations for the devices your using in the PF configuration?
Did you disable uPnP before setting up the PF configuration?
beansontoast
hello!
Thanks for your quick reply.
The router just connects straight to the little Openreach Fibre thing, which doesn't seem to have a manufacturer or model number on it - it's just a wall mounted box, about 8cm x 8cm that says "Openreach" - connected by Ethernet to the Orbi router... & then has the fibre cable to the internet coming out of it on the other side. Worked with my previous 2 routers doing port forwarding absolutely fine, though.
Yes - IP reservations are set .
No - haven't turned off uPnP. Does Orbi only support Port Forwarding with uPnP turned off?
- FURRYe38Jun 06, 2022Guru - Experienced User
Most routers need uPnP disabled if you set a manual PF configuration. Something to try.
- beansontoastJun 06, 2022Aspirant
Ah, cool. I have really very little idea what uPnP is - so I'll turn that off & see how we go! 🙂
Thanks!
Think of it as a automatic port forwarding configuration tool. Automatically sets up port configurations were needed with out any user intervention.
