orbira
Aug 24, 2020Apprentice
Orbi wifi 6 RBK753s-100NAS satellite AP mode woes
Hi, I bought RBK753S and it is replacing RBK53. I configured the router to AP mode (behind FIOS Quantun gateway) and Satellite won't connect with wireless backhaul. Was able to get them going wit...
orbira
Aug 25, 2020Apprentice
As I powered on the router connected behind FIOS Quantun gateway, it switched itself to 10.x.x.x network to avoid conflict with Quantum IP address range. I then paired the satellites which got 10.x.x.x addresses as well. Then I switched the router to AP mode and had created a static reservation for the RBR on Quantum gateway, which got its reserved IP. However, the satellites never connected back despite trying exactly what you said. Pressed the sync button on RBS and the tried both ways on screen button (add satellite option) or on the back of the router sync button, but it kept on failing. Then I connected the RBS to the lan ports on the RBR (one at a time) and then I was able to sync. I was hoping now I could remove the network cable and it would stay sync, but it did not connect in wirelees mode.
Anyways, I might try once more, otherwise may be i have bad router/satellite hardware and they are going back unfortunately.
The process is not rocket science, I am upgrading them from RBK53 (the non AX older version of Orbi mesh) and the process was relatively straigth forward.
Thanks
Aug 25, 2020Guru - Experienced User
I would configure the RBR first for AP mode. Set static or dynamic on the RBR. Try Dynamic first. Once the RBR is fully in AP mode, factory reset the RBS then try to sync. It should sync with the RBR and get a IP address from the host router...
- orbiraAug 31, 2020Apprentice
Thanks, finally ended up returning and buying new and removed the verizon FIOS router and using just Netgear. Router is setup fine, however now there is a new issue that port forwarding works from the hosts outside the LAN, but from LAN hosts if I use WAN IP to connect to internal hosts it does not work. Opening a separate thread on that.
Thanks for your help with this.
- FURRYe38Aug 31, 2020Guru - Experienced User
Enjoy.
