orbira
Aug 24, 2020Apprentice
Orbi wifi 6 RBK753s-100NAS satellite AP mode woes
Hi, I bought RBK753S and it is replacing RBK53. I configured the router to AP mode (behind FIOS Quantun gateway) and Satellite won't connect with wireless backhaul. Was able to get them going wit...
Aug 25, 2020Guru - Experienced User
I would configure the RBR first for AP mode. Set static or dynamic on the RBR. Try Dynamic first. Once the RBR is fully in AP mode, factory reset the RBS then try to sync. It should sync with the RBR and get a IP address from the host router...
orbira
Aug 31, 2020Apprentice
Thanks, finally ended up returning and buying new and removed the verizon FIOS router and using just Netgear. Router is setup fine, however now there is a new issue that port forwarding works from the hosts outside the LAN, but from LAN hosts if I use WAN IP to connect to internal hosts it does not work. Opening a separate thread on that.
Thanks for your help with this.
- FURRYe38Aug 31, 2020Guru - Experienced User
Enjoy.
