Pat-D
Dec 23, 2021Follower
Orbi WiFi 6 (RBR850) Backhaul Status Out of Sync w/ Satellite (RBS850)
I am having trouble keeping the satellite synced with the router. In an effort to resolve the issue, I would reboot the router where they would sync momentarily, then go out of sync. All wireless dev...
- Apr 06, 2022
I recommend trying this next time you need to update RBS FW:
bbninja wrote:
I had to update the firmware on my satellites to fix this issue, but that wasn't as easy as it may seem. My satellites weren't reporting their firmware version on the Firmware Update page and they were not indicating that an update was available. I had to unplug each satellite (I did one at a time), then plug it back in, let it boot up, then revisit the Firmware Update page in the router utility, and check for updates. At this point, the satellite showed I was still on a version 3 software. It also indicated that an update was available. I updated one at a time. Each worked. Since those updates, each satellites backhaul status has been Good.
Dec 25, 2021Guru - Experienced User
Any progress on this?
Pat-D wrote:
I am having trouble keeping the satellite synced with the router. In an effort to resolve the issue, I would reboot the router where they would sync momentarily, then go out of sync. All wireless devices will only connect to the router, and not the satellite, even when standing right next to the satellite.
I have a NAS and a PC that are wired directly to the satellite. These wired devices operate correctly, although I can not see them connected to my router. Since I can't see them on my router, I can not assign an IP address to them.
Can you provide any guidance?
- quethrosarJan 07, 2022Star
2 years and no changes and now first time out of sync for me. what you all break in the firmware?
- FURRYe38Jan 07, 2022Guru - Experienced User
