Pat-D
Dec 23, 2021Follower
Orbi WiFi 6 (RBR850) Backhaul Status Out of Sync w/ Satellite (RBS850)
I am having trouble keeping the satellite synced with the router. In an effort to resolve the issue, I would reboot the router where they would sync momentarily, then go out of sync. All wireless dev...
- Apr 06, 2022
I recommend trying this next time you need to update RBS FW:
bbninja wrote:
I had to update the firmware on my satellites to fix this issue, but that wasn't as easy as it may seem. My satellites weren't reporting their firmware version on the Firmware Update page and they were not indicating that an update was available. I had to unplug each satellite (I did one at a time), then plug it back in, let it boot up, then revisit the Firmware Update page in the router utility, and check for updates. At this point, the satellite showed I was still on a version 3 software. It also indicated that an update was available. I updated one at a time. Each worked. Since those updates, each satellites backhaul status has been Good.
bbninja
Apr 06, 2022Aspirant
Apr 06, 2022Guru - Experienced User
