acebeforejack
Dec 20, 2019Aspirant
Orbi wifi 6 RBR850 hardwire speeds slow
I recently upgraded my home wifi to the newest Orbi wifi 6 imesh, (RBR850) Before i changed out my other router i tested my speeds hardwired and wirless. I am getting 1g thru comcast.. Before i switc...
Dec 20, 2019Guru - Experienced User
Are you sure you are connected to the RBS in the living room with the phone? Besure that when you move near the RBS, turn OFF the iphones wifi for 5 seconds then back on so it will connect to the RBS.
Download and install WiFi Sweet Spots on the iphone to check the connection rate between the iPhone and RBR and RBS.
- acebeforejackDec 20, 2019Aspirant
Firmware Version
V3.2.8.5_1.2.3Modem is a arris Model sb8200
Ill try the sweet spot app and try reconecting the iphone to wifi. Thank you for your help.
