acebeforejack
Dec 20, 2019Aspirant
Orbi wifi 6 RBR850 hardwire speeds slow
I recently upgraded my home wifi to the newest Orbi wifi 6 imesh, (RBR850) Before i changed out my other router i tested my speeds hardwired and wirless. I am getting 1g thru comcast.. Before i switc...
Chuck_M
Dec 23, 2019Mentor
Are there any switches involved in the wiring>?
acebeforejack
Dec 24, 2019Aspirant
No switches , hardwired 5 ft away from the Orbi router - Same wire and distance as when I had the old router , Crazy thing is, I plugged a laptop in the router (next to my pc) run the same speed test and it comes back 840mbps.. My main PC reads 317mbps - same upload though. Before I changed to Orbi everything that was hardwire would read 700-900 mbps
- swittersDec 24, 2019ApprenticeSimilar thing here.
iMac Pro > Ethernet wall port > Xfinity router = 930 Mbps
MacBook Pro > USB to Ethernet adapter > Xfinity router = 930 Mbps
Either computer > Ethernet > Orbi AX > Xfinity modem = 80-200 Mbps
I actually disconnected the Orbi system and went back to Xfinity + xFi pods until I figure this out. The speed of my wired connection for my iMac Pro is more important than faster wireless (and I wasn’t really even getting that with Orbi).
I’m considering Unifi wireless access points as an alternative.- Chuck_MDec 25, 2019Mentor
Do either of you have anything on your network (hard wired) like Sonos speakers?
- swittersDec 25, 2019Apprentice
Don't mean to hijack this thread, but yes, I do. I have a wired Sonos setup. This means that I had a Sonos Play:1 plugged in to one of the LAN ports of the Orbi router.
That worked just fine when it was plugged into a switch connected to the Xfinity router. Is there a problem with that with Orbi?
- acebeforejackDec 25, 2019AspirantSwitters, are you running the Orbi with the XFi modem them provided ? I just updated to XFi to get unlimited.. They shipped me the XFi modem unit, but I’m still using my Arris modem .
- swittersDec 25, 2019ApprenticeYes, I have the XB6 modem/router they provided. I put it in Bridge Mode whe. I set up the Orbi.
