DoctorA's avatar
DoctorA
Luminary
Nov 02, 2019
Orbi WiFi 6 Router AX6000 / RBR850 New Firmware V3.1.6.11_1.1.5
What is new?
My wish list:
1.Wireless connectivity to Orbi Outdoor WiFi Range Extender (RBS50Y) since it is only wireless with no Ethernet ports.
2. Wireless connectivity to RBS50 satellite. It was reported working fine wired but it would be nice to put where you want for the second satellite location.
My system is working fine and Attached Devices list is not lost. Speeds are 1Gbps wired and 600Mbps on iphone Xs Max at both R and S rooms while conected wired together.
  • I agree that enabling wireless connectivity to Gen 1 Orbi will be nice. It will be great to be able to make use of existing HW.
    I think the wireless connectivity to Gen1 Orbi will come in a maintenance release soon.
    • sabeens's avatar
      sabeens
      Is this a fw already out? Not seeing it on my end. Desperate need of a new one, really having some weird behavior I need help on.
      • Chuck_M's avatar
        Chuck_M
        Mentor
        That is the FW that was available under ADVANCED, ADMIN tab and FIRMWARE UPGRADE.
        If that is not showing, I would recommend a factory reset and subsequent setup where it should check for that.  (Sounds like you should do one anyway!)
        The above is what I did (I actually took an extra step and factory reset AFTER the firmware upgrade just to ensure there were no hanging "chads")
        I have to say, my AX is working now like a champ including the included RBS-850 sattelite AND two RBS-50 hardwired Sattelites as well that go to a separate building.
        I have also found that the RBR-850 and RBS-850s have a MUCH wider range of coverage to wireless devices that under the old RBR-50 and RBS-50 were minimal signals... now they are maxed out.  Said another way, unless you have separate buidlings you want to cover, there may not be a need for the average home (3,000-5,000 sq/ft) to have additional sattelites.
        Final note & lessons learned:  I had forgotten you have to enable remote management in the GUI before the app would let you do management outside of the LAN (e.g. WAN).
        I had tried to hard wire to old RBR-50 in AP mode, but the system didnt like that, so I took the RBR out and replaced it with an RBS hardwired, and POOF, Bob's your Uncle!   Worked great.
        The biggest pain so far is transferring ownership of the old RBR-50 to a friend of mine.   Why isnt transfer an online function for registered owners?
    • thedak's avatar
      thedak
      Apprentice
      Hi, how did you get your RBS50 to connect to our RBR850?  I have a RBR850 with two wireless RBS850's and I tried to cable an older RBS50 but it wasn't recognized.  Just came up with the default router ssid and wouldn't sync, etc?  thanks!
      • Chuck_M's avatar
        Chuck_M
        Mentor
        My 2 x RBS50s are hard wired back through a NG switch to the RBR850.
        Just plug them in and they will be recognized.
        Wireless doesnt work (yet) for RBR850 to RBS50 backhaul.
    • Chuck_M's avatar
      Chuck_M
      Mentor
      Thanks, will give it a go after work today and report findings.
