jgiampaolo70
Jun 20, 2023Tutor
Orbi WiFi 6 Router RBR750 — - I have gig service and only get 180Mbps dowload from Orbi speed test
Good afternoon. I have the Orbi RBR750 with 4 satellites and have a question about my wired speed. I have fiber going to the outside of my house and from there a Cat6 cable that connects to my Orbi...
jgiampaolo70
Jun 22, 2023Tutor
"Can you connect a PC directly to the network and bypass the Orbi? If you do that and run speedtest on the PC, how does that look?"
Internet from the outside world connects to my Orbi router and I have a cable going from the Orbi to a 48 port switch. My PC is hardwired into the network and when I run a speed test via the Orbi admin page I get lower than 200Mbps. All cabling is either Cat5e or Cat6.
Speed test results:
Ookla - 591
Fast.com - 840
Google Speedtest - 218
bullm00n
Jun 22, 2023Virtuoso
jgiampaolo70 wrote:"Can you connect a PC directly to the network and bypass the Orbi? If you do that and run speedtest on the PC, how does that look?"
Speed test results:
Ookla - 591
Fast.com - 840
In that is that case, you should be able to temporarily connect the PC directly to your internet if you disconnect it from the switch and connect the PC in place of the Orbi. Then you can run a speedtest to verify that your network coming to the Orbi is 1Gb.
But I don't get that last bit with three different Speedtest results. How / where did you run those?
- jgiampaolo70Jun 22, 2023Tutor
Speed tests were run from my PC. Damn speed is all over the place.
