jgiampaolo70
Jun 20, 2023Tutor
Orbi WiFi 6 Router RBR750 — - I have gig service and only get 180Mbps dowload from Orbi speed test
Good afternoon. I have the Orbi RBR750 with 4 satellites and have a question about my wired speed. I have fiber going to the outside of my house and from there a Cat6 cable that connects to my Orbi...
bullm00n
Jun 22, 2023Virtuoso
jgiampaolo70 wrote:Good afternoon. I have the Orbi RBR750 with 4 satellites and have a question about my wired speed.
I have fiber going to the outside of my house and from there a Cat6 cable that connects to my Orbi Router. When I run a speed test from my hardwired PC or the router itself I am only getting around 187Mbps down and up is 940Mbps.
I am sure I am just not knowledgeable enough but shouldn't I be getting much higher download speeds? My ISP says having gig service usually runs around 875 to 975Mbps down.
Thank you in advance.
Yes, you should be getting close to 1G download especially if you run speedtest from the Orbi admin page or the Orbi app.
It could be a bad Cat6 cable. If you can try another cable, that may be the easiest thing; doesn't have to be Cat6, Cat5e will work fine too.
Can you connect a PC directly to the network and bypass the Orbi? If you do that and run speedtest on the PC, how does that look?
jgiampaolo70
Jun 22, 2023Tutor
With my PC directly connected to the internet line it is hitting 300, so I am guessing the ISP screwed up when provisioning my gig speed.
