lsw3
Dec 28, 2020Aspirant
ORBI Wifi 6 setup with Comcast/Xfinity XFi...
Looking for recommendations for the best way to set up an Orbi 6 mesh system (RBK752) with our Comcast/Xfinity XFi modem/router? It's a multi-level home with work-from-home and multiple gamers...thou...
Dec 28, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
lsw3
SqFt is approx. 4,500...the distance between the two Orbi would be more than 30 feet.
The Xfinity wireless Gateway is a XFi Technicolor CGM4140COM (if that makes any difference)
- FURRYe38Dec 28, 2020Guru - Experienced User
Ok, Distance can be up to around 60 feet between the RBR and RBS. you'll need to play around with placement to see how the RBS connect. No less that 30 feet though.
You have info about your ISP modem.
Good Luck.
