lsw3
Dec 28, 2020Aspirant
ORBI Wifi 6 setup with Comcast/Xfinity XFi...
Looking for recommendations for the best way to set up an Orbi 6 mesh system (RBK752) with our Comcast/Xfinity XFi modem/router? It's a multi-level home with work-from-home and multiple gamers...thou...
lsw3
SqFt is approx. 4,500...the distance between the two Orbi would be more than 30 feet.
The Xfinity wireless Gateway is a XFi Technicolor CGM4140COM (if that makes any difference)
Dec 28, 2020Guru - Experienced User
Ok, Distance can be up to around 60 feet between the RBR and RBS. you'll need to play around with placement to see how the RBS connect. No less that 30 feet though.
You have info about your ISP modem.
Good Luck.
