SkySys
Aug 23, 2020Guide
Orbi WiFi 6 Slow WiFi/Inconsistent Speed
First Issue - unable to find the correct model in Netgear Support, so chose the closes model one in the list (RBR50 Orbi AC300). * My Correct Product is RBR750, Netgear AX4200 Orbi WiFi 6 with 1 Sat...
SkySys
Aug 24, 2020Guide
Yes, I have tried both speed test hardwired and wireless. Before and After Orbi. It increased a little bit after Orbi. But still not getting that 500 to 600mbps + speed.
AT&T Aris Modem and Router doesn’t allow bridge or modem mode. The closest you can do is IP Passthrough.
The IP Address is showing 108... and on Orbi login it’s 192 and I have also set it as static IP address.
Any other suggestions?
Aug 24, 2020Guru - Experienced User
What are your wired speeds behind the RBR? You should see near 900Mpbs on wired with your mac.
Wireless, you should see anything from 500 to maybe 700 on your mac book as I do with mine sitting around 10-12 feet way from the RBR.
What happens if you try AP mode on your RBR?
- SkySysAug 25, 2020Guide
Yes, I am getting on average 950mbps.
Wireless I am sitting closer to 300 to 400 max, fluctuating.
I have tried AP mode and has not made a difference.
- FURRYe38Aug 25, 2020Guru - Experienced User
What Connection rates are you seeing on the mac book and iphone. Use wifisweet spots on your iphone to check the connection rates there.
- SkySysAug 25, 2020GuideThanks for the app suggestion. I tried it and it gave me on average 300mbps. Definitely not getting the WiFi 6 speeds.
