SkySys
Aug 23, 2020Guide
Orbi WiFi 6 Slow WiFi/Inconsistent Speed
First Issue - unable to find the correct model in Netgear Support, so chose the closes model one in the list (RBR50 Orbi AC300). * My Correct Product is RBR750, Netgear AX4200 Orbi WiFi 6 with 1 Sat...
SkySys
Sep 13, 2020Guide
I agree, I have been obsesses with trying to get 600 to 700+ on these newer devices, looks like it won't work.
But, trying to at least get 400 + consistently on all he devices, as it is fluctuating from 100 to 300 right now. In the same spot.
Mikey94025
Sep 13, 2020Hero
SkySys wrote:I agree, I have been obsesses with trying to get 600 to 700+ on these newer devices, looks like it won't work.
Unfortunately with the advertised high speeds of the new Orbi AX systems too often people here complain about "why do I only get XXX wireless speed". We really need a FAQ post or something to just give the same answers, for example:
- Make sure you're using bridge mode and not Double NAT
- Test wired speeds vs. wireless speeds to determine if its a wireless issue or upstream bandwidth issue
- Use the speedtest.net app and not the Orbi built-in speed test
- Test using an AX device like iPhone 11 Pro
- Wireless speeds can never match wired speeds
- etc.
I have learned not to obsess with getting the highest wifi speeds via the Orbi. It's too variable, depending on how my iPhone 11 Pro has decided to connect (AX or not) and other wifi factors.
- SkySysSep 13, 2020Guide
I understand your point, but the marketing is sending lot of wrong messages, where it shoud be a "Plug and Play" solution. It makes me think if I should have gone with the Eero solution to get beter results.
- Dd852Sep 13, 2020Luminary
What I honestly don't get is how much of the issue is down to Orbi and how much to Apple. Ultimately the devices themselves decide which band to connect to and when to switch. So basically we have the intelligence of the Orbi mesh meeting the intelligence of the iphone and they clearly don't always make a smooth handoff.
- Mjacobs732Sep 26, 2020Tutor
I have been having similar problems. On installation, speeds were good. Now:
Ethernet to modem (Xfinity, rated at 300 mbps): 350 mbps
Ethernet to router : 60 mbps
WiFi router to iPhone 11 (3 ft away) : 14 mbps (fluctuates)
I rebooted and it was fast briefly and then degraded.
I have talked with three people at NG tech support; each said he/she was not qualified on this issue. I have now been on, mostly on hold, for 100 minutes. Fortunately, I bought this at Costco, which is good about returns.
But seriously folks: it is 2020. Can't we get WiFi to work reliably?
- AkahoganSep 26, 2020Tutor
Keep track of your return time period. The Netgear Support took so long to do initial investigation that I went past the 30 day window for returning. I even offered to buy a newer system that was more powerful if they felt it would help, no response. Towards the end they wanted me to provide every model and type of device connected to troubleshoot. I told them that if this is a consumer product, then make it so a consumer can use it. Install software to do better diagnostics and automatically suggest changes based on the performance it tracks. All of the information is going through the router, they could do it and maintain privacy and security concerns.
Best of luck to you, looks like Netgear may have lost another customer for poor performance and experience. Maybe it won't matter because enough people like their products, but maybe the message will get through the more people complain.
- FURRYe38Sep 27, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Mjacobs732 wrote:I have been having similar problems. On installation, speeds were good. Now:
- Mjacobs732Sep 27, 2020Tutor
I think I found the culprit. I have a microcell attached to one of the Ethernet ports in the router. Since disconnecting it this morning, the system has been stable and fast.
Really...What is the mfr and model # of this microcell? I have a ATT microcell connected with mine.
- Mikey94025Sep 27, 2020Hero
Mjacobs732 wrote:I think I found the culprit. I have a microcell attached to one of the Ethernet ports in the router. Since disconnecting it this morning, the system has been stable and fast.
That is surprising... What can cause a connected device like this to degrade other Orbi device speeds?
- Mjacobs732Sep 27, 2020TutorYes, I know. It is a Cisco microcell. With WiFi calling, it is no longer needed. Five hours later, all is well with the ORBI.
Is it WHITE and Orange under casse? Mine is Cisco but has the ATT emblem on the side and is white and orange. I keep mine online for back up. Also notice that I can't send text messages via wifi network and we have low cell signal here so I keep mine online. It sits behind a switch though.
