Cyclechick's avatar
Cyclechick
Initiate
Jan 11, 2021
Orbi wifi 6 speed test in orbi app not working
I have the Netgear Orbi Router RBR 750. The app has a speed test option and when I select to use it it tells me ‘connection failed, if problem persists reboot your router’. I have reboot my router twi...
  • Cyclechick's avatar
    Jan 18, 2021
    I ended up doing a factory reset and that fixed the issue.
