Cyclechick
Jan 11, 2021Initiate
Orbi wifi 6 speed test in orbi app not working
I have the Netgear Orbi Router RBR 750. The app has a speed test option and when I select to use it it tells me ‘connection failed, if problem persists reboot your router’. I have reboot my router twi...
- Jan 18, 2021
I ended up doing a factory reset and that fixed the issue.
PRobes
Jan 14, 2021Aspirant
Hello, I have the same issue with the internet speed test for my RBR750 mesh system. The app reports "connection failed," and I have rebooted the router several times and reinstalled the app as well. The speed test within the browser window when I log in from my desktop PC also will not update.
I just switched to a new ISP and want to verify I am receiving the speed I am paying for. What is the solution to this problem?
Thank you.
Jan 14, 2021Guru - Experienced User
Has a power off for 1 minute then back on been performed on the RBR and ISP Modem?
