Cyclechick
Jan 11, 2021Initiate
Orbi wifi 6 speed test in orbi app not working
I have the Netgear Orbi Router RBR 750. The app has a speed test option and when I select to use it it tells me ‘connection failed, if problem persists reboot your router’. I have reboot my router twi...
- Jan 18, 2021
I ended up doing a factory reset and that fixed the issue.
Cyclechick
Jan 18, 2021Initiate
- FURRYe38Jan 18, 2021Guru - Experienced User
Thanks for letting us know. Please mark your thread as solved so others will know.
Enjoy.
