Zurg-orbi
Nov 24, 2020Aspirant
Orbi WiFi 6 System AX6000 (RBK852) Double Link Aggregation 2.5Gb + 1Gb
Hi
I will get a 10Gb internet connection with a SFP+ port on the modem .
I am wondering if the RBK852 will benefit from an aggregation with a 2.5 Gb + 1 Gb Connection to the SFP+ switch ?
i.e. is the aggregation only for 1 + 1 Gg ?
Thank you
If its anything like my RAX200, it only suppors 1+1.
I don't have a Orbi to compare it to but the manual shows 1+1 as does the guide.
https://kb.netgear.com/000061324/How-do-I-set-up-WAN-aggregation-on-my-Orbi-WiFi-6-System
- Zurg-orbiAspirant
Thank you very much for your help . It is clear now . I will only connect the 2.5 Gb port .
Too bad that I cannot use the 3.5Gb (out of 10) for multiple devices.
