LawKrush
Jul 24, 2020Aspirant
Orbi WiFi 6 System (RBK752) Forcing 2.4GHZ on certain devices
Hi all, My Arlo Baby montiors (two (2) of them) are pretty far away from the router and above (upstairs) from the satelite. It's currently showing that its connected to the 5ghz band, but it's v...
Jul 25, 2020Guru - Experienced User
LawKrush wrote:Hi all,
My Arlo Baby montiors (two (2) of them) are pretty far away from the router and above (upstairs) from the satelite. It's currently showing that its connected to the 5ghz band, but it's very laggy and disconnecting. Please note my wifi with this router is fantasic outside of this issue.
I feel the Arlo's need to be connected on the 2.4ghz band, however it seems there is no way to do that through the app or desktop.
Do we know if they will add that feature or are they working on such?
If not, is my only option to "forget the network" on those devices and either (i) reduce the 5ghz band to 25% output and reconnect and then bump back to 100% or (ii) turn of 5ghz, reconnect and then turn 5ghz back on? This would be the first suggestion that should work.
