jdkorbi
Jun 17, 2020Aspirant
Orbi WiFi 6 System (RBK842) AX5700
Can I purchase the AX5700 directly from Netgear and use the 10% discount?
Jun 18, 2020Guru - Experienced User
IF the model is available at there store and you have the discount code, I presume so.
- jdkorbiJun 18, 2020AspirantNetgear provides information at https://www.netgear.com/orbi/rbk842.aspx as if it's available, but the "Buy" link is not active.
