jdkorbi
Jun 18, 2020Aspirant
Orbi WiFi 6 System (RBK842) AX5700
Can I purchase the AX5700 directly from Netgear and use the 10% discount?
Jun 18, 2020Guru - Experienced User
Possible the model isn't in stock is all.
jdkorbi
At this point, a response from Netgear seems appropriate. Does the company monitor the community discussions?
- Blanca_OJun 21, 2020NETGEAR Employee Retired
Hi jdkorbi
Thank you for your interest. We have no updates at the moment on availability. However, we recommend you check our online store periodically : https://www.netgear.com/orbi/rbk842.aspx
Blanca
Community Team
