kleek1975
Aug 08, 2020Guide
Orbi WiFi 6 System (RBK853) AX6000 with Outdoor Mesh Point
I currently deploy Netgear Insight managed switches on my home network. I really like Insight App. I'm wanting to upgrade my Amplifi HD wifi system with a Orbi WiFi 6 System (RBK853) AX6000. My ho...
CrimpOn
Aug 08, 2020Guru - Experienced User
kleek1975 wrote:Does Netgear make a Mesh Point for outdoors that is compatible with the Orbi WiFi 6 System (RBK853) AX6000? Not an extender, but a true mesh point.
This question will probably get a more informed response if posted in the community forum devoted to the AX product line:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
While there may be one or two people who are active in the "regular Orbi" forum who also own an AX system, the vast majority of us are here because our product is the original WiFi5 residential Orbi.
In my opinion, you are wise to settle this issue before committing to a product.
kleek1975
Aug 08, 2020Guide
Thanks for the recomendation. I reposted as you suggested!
