kleek1975
Aug 08, 2020Guide
Orbi WiFi 6 System (RBK853) AX6000 with Outdoor Mesh Point
I currently deploy Netgear Insight managed switches on my home network. I really like the Insight App. Replacing the unmanaged switches with the Netgear Insight managed switches solved all of my L...
Aug 08, 2020Guru - Experienced User
No. The RBS50Y is an out door satellite that works only in extnder mode with Orbi AX. If you want this RBS to work in Orbi mode, then Orbi AC system is compatible, i.e. RBK50 series system.
kleek1975
Aug 16, 2020Guide
Thanks for the info. Since I have fiber with gigaspeed comng into the house, I'll just wait to upgrade until Netgear comes out with an outdoor mesh point that will work in Orbi mode with the new AX6000 system. Is that coming soon Netgear?
- FURRYe38Aug 16, 2020Guru - Experienced User
NG doesn't post information on when new products are forth coming. They usually will make an anouncement on there main web page.
