Ur_King's avatar
Ur_King
Tutor
Apr 27, 2020
Orbi WiFi 6 System (RBK853) AX6000
what's the max number of satilites that can be added to RBK853 AX6000 -- that won't compromise performance?
  • FURRYe38's avatar
    I would put in a buried CAT6A lan cable between the two buildings. Then place a RBS in the garage thats wire connected. Metal roof may impact wifi coverage.
