nrkc99
Sep 01, 2020Aspirant
Orbi WiFi 6 System (RBK853) AX6000
Does Orbi WiFi 6 System (RBK853) AX6000 have remote management so i can connect from anywhere to my home network? How can i setup it
Sep 01, 2020Guru - Experienced User
Remote management is for managing the RBR and it's configuration.
- nrkc99Sep 01, 2020Aspirant
Does remote management works for Orbi WiFi 6 System (RBK853) AX6000??
- FURRYe38Sep 01, 2020Guru - Experienced User
I believe it does. I haven't tried it a while.
ISP modem configuration can impact remote management.
https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NAT- Dd852Sep 01, 2020Luminary
It works for me but it is very basic. You can see what is attached and you can initiate a router reboot. You can pause/resume devices. That's about it. But for what it is, it is quick and good.
