nrkc99
Sep 01, 2020Aspirant
Orbi WiFi 6 System (RBK853) AX6000
Does Orbi WiFi 6 System (RBK853) AX6000 have remote management so i can connect from anywhere to my home network? How can i setup it
Sep 01, 2020Guru - Experienced User
Remote management is for managing the RBR and it's configuration.
nrkc99
Does remote management works for Orbi WiFi 6 System (RBK853) AX6000??
- FURRYe38Sep 01, 2020Guru - Experienced User
I believe it does. I haven't tried it a while.
ISP modem configuration can impact remote management.
https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NAT- Dd852Sep 01, 2020Luminary
It works for me but it is very basic. You can see what is attached and you can initiate a router reboot. You can pause/resume devices. That's about it. But for what it is, it is quick and good.
Is tha for the orbi app? If so, then yes, you only get basic status and disable devices is all.
I believe you can log into the RBRs web page with a web browser from a remote location which should give you same advanced web page features.
