nrkc99
Sep 01, 2020Aspirant
Orbi WiFi 6 System (RBK853) AX6000
Does Orbi WiFi 6 System (RBK853) AX6000 have remote management so i can connect from anywhere to my home network? How can i setup it
nrkc99
Does remote management works for Orbi WiFi 6 System (RBK853) AX6000??
Sep 01, 2020Guru - Experienced User
I believe it does. I haven't tried it a while.
ISP modem configuration can impact remote management.
https://kb.netgear.com/30186/What-is-Double-NAT
- Dd852Sep 01, 2020Luminary
It works for me but it is very basic. You can see what is attached and you can initiate a router reboot. You can pause/resume devices. That's about it. But for what it is, it is quick and good.
- FURRYe38Sep 01, 2020Guru - Experienced User
Is tha for the orbi app? If so, then yes, you only get basic status and disable devices is all.
I believe you can log into the RBRs web page with a web browser from a remote location which should give you same advanced web page features.
Yes the app. I have never tried the web page remotely. Thanks for the tip
