mgdurand1
Sep 08, 2023Luminary
Orbi WiFi 6 with 4 satellites - flawless EXCEPT drops Zoom telephone calls from work to cell
I have the Orbi WiFi6 setup with 4 satellites. Armour enabled. Have pretty much had zero problems. When I started working for a while remotely, the office ZOOM phone system allows calls to my offi...
- Sep 10, 2023
Hopefully the new FW fixes this for you.
I've been enjoying the new FW for sure.
Sep 08, 2023Guru - Experienced User
Does same thing happen with Armor disabled?
What is the size of the office building? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
mgdurand1
Sep 09, 2023Luminary
Hi, and thanks for the response. I also thought it might be Armor. Armor played havoc with my internet connections on my home network a year or so ago. They finally fixed that. This started when our office system started with a ZOOM phone system. Can set it so that if out of the office any call to the office number rings on my cell. Works for all other people in the office, but for me when I answer it works for a minute or two and then as noted above I cannot hear them on my cell but they can hear me fine. Firmware is most current: V4.6.14.3_2.3.12 for my Orbi 6 system at the house. Office building size: don't know square footage, but takes up an entire floor. My coworkers without Orbi home networks have no issues, even those with the same iPhone I use (13 Pro).
