mgdurand1
Sep 08, 2023Luminary
Orbi WiFi 6 with 4 satellites - flawless EXCEPT drops Zoom telephone calls from work to cell
I have the Orbi WiFi6 setup with 4 satellites. Armour enabled. Have pretty much had zero problems. When I started working for a while remotely, the office ZOOM phone system allows calls to my offi...
- Sep 10, 2023
Hopefully the new FW fixes this for you.
I've been enjoying the new FW for sure.
mgdurand1
Sep 10, 2023Luminary
Did not realize that the firmware had been updated so recently. Update all the satellites and then the router's firmware. Normally, when my issue would arise it would come about 3 minutes after the call connected. After the FW updates, Had someone call my office number from another phone to see if it would cut off a few minutes after connecting. It worked fine for more than 5 minutes. For the heck of it I turned on Armor again just to see if that would affect it. It did not. Monday will be a better test with loger calls, but this is encouraging. Thanks, and I will advise hoe next week goes.
Sep 10, 2023Guru - Experienced User
