neil6946
Aug 25, 2020Aspirant
orbi wifi 6
Hi I am thinking of buying the Orbi RBK853 as I have a large house with lots of deadspots and very poor internet speeds away from the main phone socket. I have sky broadband and a skyq box, and...
Aug 25, 2020Guru - Experienced User
First off what is the size of your home. Placement of Orbi and satellites will be key.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
2ndly, contact your ISP and ask them first on if some of there equipement is required for use in there services or not and if some of there equipement can work with other wifi router systems.
IF there equipment is needed, then you can still use Orbi, just will need to be in a different configuration possibly to work well with there equipment.
For modems or ONT with built in wifi and routers, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
neil6946
Aug 27, 2020Aspirant
Many thanks, that makes sense.
If I go ahead and order the equipment, does the support provided for the 90days include someone being able to talk me thorugh the set up, and in particular the changing of the settings on the modem/router if I find that I need to keep the Sky modem/router in place?
- neil6946Aug 27, 2020Aspirant
Sorry, I should have added, my home is approx 30m long and the main phone socket is at the opposite end from the TV/hifi on the same floor and then the office which is 2 floors up.
Would I need 1 satellite or 2?
Thanks
Neil
