TIJIM
Oct 02, 2021Aspirant
ORBI WIFI 6
I have a ORBI WIFI-6 model G3100 (master and one satellite. If I want to extend coverage can I just buy one more satellite and add it to the system. If so is there one you would recommend?
Oct 03, 2021Guru - Experienced User
What model is the Orbi RBK3##, 7## or 8##?
G3100 is not a NG model # for Orbi.
- plemansOct 03, 2021Guru - Experienced User
G3100 is a verizon router. Are you sure you have an orbi setup?
Of is the G3100 the gateay the orbi is connected to? - TIJIMOct 04, 2021Aspirant
Apologies. I did give the model number for the verizon router to which the ORBI router is linked. The Orbi Router and Satellite are RBR50v2. Can I just add another Sattelite to extend the coverage.
- FURRYe38Oct 04, 2021Guru - Experienced User
Yes.
RBS20, RBW30, RBS40v or RBS50 will work. EX7500, 7700 or 8000 will work in a pinch but not integrate like RBS do.
Orbi AX RBS will not work with Orbi AC systems.
Will move this thread to the Orbi AC forum.
Good Luck.
