SteveNetSpeed
Nov 13, 2022Aspirant
Orbi WiFi 6E performance
(I did look for posts about this, but I couldn't find anything that matched. If I missed it, please point me in the right direction.) I recently upgraded to faster Internet, with GotNetSpeed 1 Gbs...
- Nov 17, 2022
I'm returning it. Still have the original boxes I got it from Amazon.
I was already frustrated with the fact that it's not getting me 600 Mbps over WiFi 6MHz from 3 feet away or more than 400 Mbps upstairs, and I don't need the second satellite. At this point, I went with an Ethernet backhaul and turned off the spare satellite, so I'm barely using it for its designed features.
That's why I was frustrated. Just now, the satellite stopped working. Rebooting it didn't help. Removing the Ethernet backhaul didn't help. Turning on the spare didn't help. I could have tried rebooting the router itself and then repeating the steps to sync with the satellites and so on, but this would have been pointless.
The Orbi does not do the job I need it to and it's not even reliable for what little I ask of it. So it's gone.Thanks for your attempt to help me, though. I sincerely appreciate the time and effort you took. I am not at all likely to purchase an Orbi product in the future.
SteveNetSpeed
Nov 17, 2022Aspirant
Nov 18, 2022Guru - Experienced User
Sounds like maybe the system you have is just faulty. You might try getting just the RBR alone. They have the RBR alone for sale now and then you could add ON a RBS.
However understand the frustrations. Hope you find something that works for you.
Good Luck.
