Gdogghbk
Feb 13, 2021Aspirant
Orbi WiFi Crashing
Hi All, I recently purchased the Orbi AX6000 RBK852 to provide Mesh WiFi in my home... Upon initial setup, everything went great! I have an Arris SB6190 connected to the Orbi Router in my living...
Feb 13, 2021Guru - Experienced User
That FW version are you usuing?
v12 is the latest:
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
- GdogghbkFeb 13, 2021Aspirant
v12 is the latest:
**It’s on the Latest Version, did the Update Upon Setup**
**Home is multi-level, 1800 sq ft**
**Router is on 1st Floor, Satellite is on the 2nd Floor, for sure more than 30ft apart walking distance, may be closer through floors?**
**I went through every channel and every combo over the last week, even altering CTS/RTS as Support suggested**
**Probably everyone in the neighborhood, lots of WiFi’s show up in NetSpot, but none appeared overpowering?**
Hopefully I answered those well enough...- FURRYe38Feb 13, 2021Guru - Experienced User
So if you turn OFF the RBS, does the wifi on the RBR still not work well?
- GdogghbkFeb 13, 2021AspirantI unplugged the RBS, unfortunately the WiFi still crashes...
- Chuck_MFeb 13, 2021Mentor
v12 is the latest:
**It’s on the Latest Version, did the Update Upon Setup**I think if you go to your web interface (192.168.1.1) and read the number in the top right corner, you will most likely find it is NOT the most current version because a manual update is necessary to get to the latest version.
It should be V3.2.17.12_1.4.14
Can you check that one more time?
v12 is is reference to V3.2.17.12_1.4.14
