Gdogghbk
Feb 13, 2021Aspirant
Orbi WiFi Crashing
Hi All, I recently purchased the Orbi AX6000 RBK852 to provide Mesh WiFi in my home... Upon initial setup, everything went great! I have an Arris SB6190 connected to the Orbi Router in my living...
Gdogghbk
That FW version are you usuing?
v12 is the latest:
**It’s on the Latest Version, did the Update Upon Setup**
**Home is multi-level, 1800 sq ft**
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
**Router is on 1st Floor, Satellite is on the 2nd Floor, for sure more than 30ft apart walking distance, may be closer through floors?**
**I went through every channel and every combo over the last week, even altering CTS/RTS as Support suggested**
**Probably everyone in the neighborhood, lots of WiFi’s show up in NetSpot, but none appeared overpowering?**
Hopefully I answered those well enough...
