OrbiEd
Jul 10, 2021Aspirant
ORBI wifi not visible
ORBI RBR750, Just purchased orbi RBR750 with one satellite but can't set up on phone app as the orbi wifi is not visible on any device in house. Model # not available in field above, 2nd forum to post...
Jul 10, 2021Guru - Experienced User
Try a different wifi device and Orbi app?
Try setting up the RBR and RBS with a wired PC or laptop connected to the RBR and web browser pointed to 192.168.1.1
OrbiEd
The WiFi I am trying to see is the Orbi wifi, so if not visible on huawei phone, iPhone, Samsung phone and IBM laptop, I suspect the issue is the Orbi and using a different app will still have the step, connect to the orbi wifi.
I could try connecting the orbi to the pc but this does not follow the netgear instructions and I would not be fully confident on what settings I would need to be setting.
- FURRYe38Jul 10, 2021Guru - Experienced User
You would follow what is seen in the setup wizard that will help you out in regards as to what you'll be doing.
- OrbiEdJul 12, 2021Aspirant
MODEL: Orbi RBR750
Maybe aI'm not explaining correctly, I will try explain again a bit clearer.
The Netgear App ORBI is the app recommended to download and follow the steps which takes you through the steps required to get connected. The App tells the user on you phone to connect to the ORBI wifi. The ORBI WIFI is not visible to any device in my house, as mentioned above , laptops or phones. So I cannot follow the netgear instructions since I have come to a stop. Using any other app will result in the same since none of my devices can see the wifi from the ORBI.
- FURRYe38Jul 12, 2021Guru - Experienced User
Try setting up the RBR and RBS with a wired PC or laptop connected to the RBR and web browser pointed to 192.168.1.1. See if you can set up the RBR here and give a new SSID name. See if this appears on your devices. If it doesn't, you'll need to get the system replaced as it would be faulty.
