Lewes1973
Mar 23, 2022Tutor
Orbi Wifi6 (RBK850+RBS850) + Philips Hue + Homekit issue
Hello All, I recently bought and installed an RBK850+RBS850 combo to exchange my old Amplifi HD setup. Devices are running on the latest firmware (4.6.7.13) connected to each other wirelessly. Ther...
Mar 23, 2022Guru - Experienced User
What happens if you disable AX mode on 2.4Ghz on the RBR?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
