Lewes1973
Mar 23, 2022Tutor
Orbi Wifi6 (RBK850+RBS850) + Philips Hue + Homekit issue
Hello All, I recently bought and installed an RBK850+RBS850 combo to exchange my old Amplifi HD setup. Devices are running on the latest firmware (4.6.7.13) connected to each other wirelessly. Ther...
Mar 23, 2022Guru - Experienced User
What happens if you disable AX mode on 2.4Ghz on the RBR?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Lewes1973
Mar 23, 2022Tutor
AX mode is already disabled on 2.4Ghz, but the devices connected to 5Ghz, where it is enabled.
The house is 100squaremeter, the router and satellite is around 8 meters to each other, but the router is in a rack cabinet, plus there is a door between the 2 devices.
