Lewes1973
Mar 23, 2022Tutor
Orbi Wifi6 (RBK850+RBS850) + Philips Hue + Homekit issue
Hello All, I recently bought and installed an RBK850+RBS850 combo to exchange my old Amplifi HD setup. Devices are running on the latest firmware (4.6.7.13) connected to each other wirelessly. Ther...
Lewes1973
Mar 23, 2022Tutor
AX mode is already disabled on 2.4Ghz, but the devices connected to 5Ghz, where it is enabled.
The house is 100squaremeter, the router and satellite is around 8 meters to each other, but the router is in a rack cabinet, plus there is a door between the 2 devices.
Mar 23, 2022Guru - Experienced User
Try disabling AX mode on 5Ghz and see.
10 meters would be preferred between the RBR and RBS and in between each RBS...
- Lewes1973Apr 04, 2022Tutor
Going back to this topic - so far I was not able to fix the issue. Anything I change, the original problem remains, and the only way is to disable/enable wifi, or completely reboot the iPads.
Any other suggestion?
