sanchitjoshan
Mar 12, 2022Aspirant
Orbi Wifi6 system inter-operability for RBS350 satellite with a RBR750 router
Hi,
Is there a detailed compatibility chart across orbi wifi6 systems?
I’d like to know if a RBS350 satellite (dual band) will work in an existing setup of RBK753 system connecting to a RBR750 router (tri band) to extend the range, albeit at a lower cost and lower performance?
Pls let me know. I’m assuming both being wifi 6 systems, this might be possible?
Yes.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡- sanchitjoshanAspirantThe place is about ~7500sq.ft. across a single floor with lots of walls.
I already have a RBR750 in the middle and a RBS750 each on 2 opposite ends.
There’s another area that’s a dead zone right now and the nearest device is the RBR750 which doesn’t sufficiently cover the area.
I’m looking to xpand the coverage by adding a RBS350 instead of RBS750 as speed is not a high priority and I’m looking for full coverage with moderate speeds at lowest cost…- FURRYe38Guru - Experienced User
