mbarylski
Sep 03, 2020Guide
Orbi: Wired and Wireless devices behave as if they're on separate networks
I read about a similar issue in these forums, but the solution didn't work. This is just really strange. I have the Orbi AX6000 with 1 satellite. Wired devices are hooked up to a 24-port Netgear swit...
Sep 03, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Is the RBS wired or wireless connected to the RBR?
What happens if you take the PC and directly wire (no switch) it to the back of the RBR and connect the wireless device to the RBRs wifi. I would turn OFF the RBS for this quick test.
