kamran185
Dec 21, 2024Follower
Orbi wired backhaul Satellite not recognised
Hi, I have RBR850 with 4 Satellites. When I plug the ethernet (through the switch) into one of the satellites, the router no longer recognises connection with that Satellite (shows as disconnected on ...
Dec 21, 2024Guru - Experienced User
What happens if you connect the RBS directly behind the RBR and by pass the switch? Seen then?
What brand and model # is the switch?
Be sure your using good quality LAN cables as well, CAT6 is recommended.
What Firmware version is loaded on the RBS and the RBR?
